Info : Can I Expect Any Nasty Surprises ?
Fonz
New to the forum and on the beg for info already. I'm currently shooting about in a '96 Corolla Si and the brake pads and discs require replacing.
Could anyone shed any light on pitfalls which I might encounter while attempting this or any hints in general ?
No nastiness as far as i'm aware, just use lots of wd40 or similar.
two bolts top & bottom securing the bracket for your pads are generally easy to slacken
It's the two bolts holding the actual caliper on which can be quite tight, i used a breaker bar
on mine when i took them off to spray them, your disc should just come off dead easy.
:D
