Side Steps For Rav4 4.1 ! ?
Zincubus
Where is the cheapest place to get a pair of side steps for our Rav4 ?
Just for eye candy really so even a cheap pair of side bars or vnerf bars would be ok .
Any for sale or links to web pages would be useful.
tried eBay with not much luck.
Thanks peeps .
Hi Zincubus - I have no knowledge of this, but here is a suggestion.
Go to a decent exhaust place that also fabricates Stainless Steel custom exhausts - they should be able to make up a couple of nice looking side bars and weld on brackets that match up with the side mounting plates on the car (assuming there are some?).
If you got a set of end caps for the rav 4.2 "style pack" side bars, you could fit those to the ends and voila - nice set of custom sides for you :D
cost wise, who knows? you are talking about two straight bits of SS tubing, and 4 brackets, so shouldn't be too much :)
Try a catering stainless steel fabricator and give them a template/profile of what you want. I did for the back step and it cost me £20.
3 or 5 door mate ?
Cheers
Nat
3 or 5 door mate ?
Cheers
Nat
Is this a trick question??
The rear step will be the same for both - but mines a 3 door as some folk on here know only too well!!
You might find the side steps are different for the 3 door and the 5 door :P But the same method applies.
3 or 5 door mate ?
Cheers
Nat
Erm..no..is this a trick answer ? !! read the post again..the guys looking for side steps whcih will be different for 3 and 5 door models ?!! lol
