Help Removing Driveshaft From Avensis Gearbox!
mnahit
I'm trying to take out the left hand driveshaft from a gearbox (the one without the centre bearing) on my 2002 1.8 avensis. Just can't get it to budge. Am I missing anything?
Any help gratefully received,
Two options:
(i) Pri - bar Use as lever or
(ii) Pri-bar, use as drift together with hammer/mallet.
http://www.machinemart.co.uk/shop/product/...pce-pry-bar-set
The inboard splined end of the driveshaft is only held with a small metal clip. The lips on the drive shaft rubber seals are easily damaged so be careful on refitting
HI,
thanks very much for getting back so quickly. My largest snap on pry bar won't shift it !! :crybaby: and that's after i made a hole in the gbox casing so i had somewhere to leaver against (gbox has self destructed due to a prob with bearings, yes Toyota another one!!)
Just off back out to shout at it see if that helps
Any other sugestions
  • 13 years later...
Hi, interesting read as I too am having problems with getting the drive shaft out, did you ever solve your problem, if so how?
