Carina 3s-fe Engine Drain Plug
atlat
where is the engine coolant drain plug on the engine block; 3S-FE engine??
have a description, or picture??
thanks
What do you mean engine coolant.
I have a 3s-fe celica the sump plug is on the bottom of the sump where you would expect to find it. Are you looking for a plug somewhere to drain the engine block of water? I dont know why you would need to do this...and have never seen one on any car engine
