Speedometer On My Ae92 Gti
gt-four/gt-i 16
Has this happened to anyone?
cruising at 60 mph in my ae92 gti, my speedometer dropped to zero and my mileage counter just stopped.
i believe it could be a speed cable gone?
can anyone shed any light?if so can i get this in a motor factors & approximately how much does one cost?
thanks in advance!
thanks in advance!
Could be one of three things, first, check that the speedo drive cable is secured into the gearbox, you'll find it by looking for the cable coming out of the drivers side of the bulkhead and continuing on down to the gearbox, if you like you can remove it from the gearbox and twist the needle at the end of the cable while getting someone inside the car to see if the speedometer is moving, if it is, then your cable is ok, and it'll probably be the speedo sender unit that bolts into the gearbox. If you do need a cable, you'd be better off getting a genuine toyota one from a dealers..
thanks in advance!
Cheers mate will check dat out.
