Sub
howard1982
i cant see a hole behind glovebox to run a power cable from Battery to boot does it come out the glove box
. shall i make one or how do i take glovebox off
Start in the engine bay side. There's a large rubber grommet where a lot of other wiring goes through the bulkhead (near the battery). This has 2 smaller nipples sticking out of it, cut one of them off and feed cable through the hole, it should appear in the passenger footwell. Hope that helps.. :thumbsup:
Stu
2nd stu's example. This is what I also did. Good luck
