Master Cylinder & Clutch Problems T3-x Avensis D4d
afrobengali
hello friends i have a t3x avensis d4d i my clutch has become very heavy and the master cylinder has started creaking . toyota main dealer have quoted me £1700 to get it all sorted out ............. ouch. so i went to a local mechanic one ive know for some time who advised me the dual mass flywheel will also need to be changed but rather tahn replacing it with a dual mass he recomended that i should replace it with a single mass flywheel from the old avensis d4d as it will last longer than a dual mass which only lasts abd 3 years will be cheaper and will not have any difference. my mechanic said to replace it with a single mass it requires some slight nut and bolt modification but nothing massive.
this modification has previously done on alot of taxi cars which are now running fine in additon to a rav4 wich has a bigger gear box .
any thoughts on wheter this will be beneficial or should i just replace it with a dual mass
