I've just finished changing an alternator on a Carina E 1.6 Kudos Extra. The previous one was the original and 161000 miles later had finally given up.
I have replaced the unit as per Haynes manual.
Disconnect Battery
Disconnect alternator
Slackened the tension on the belt
Undo bolts top and bottom of alternator
Slide out alternator
Insert new one
Tension belt
Reconnect alternator
Reconnect Battery
Started no problem, and belt is not slipping but I have NO electrics! Nothing apart from lights and hazards. No power steering, no indicators, no wipers, no dials.
Any thoughts? All ideas appreciated.
Thanks.
check that the gauge and the ignition fuses have not blown, these will cause your electrical problems. the power steering is a hydraulic pump which is belt driven, check the belt tension of the smaller belt.. hope this helps you.
I'll check it out, thanks.
