Toyota Previa
eddieh
HI eddie;
Bit more info required here, you don't say if the box actually shifts in OD or not. Chances are if it does that it could be a loose contact. Mine does that in D.
My car wont shift in OD till the engine is warm, but never flashes. Maybe it could be a reminder to tell you thah the engine has warmed up, and that you can use OD.
rick
HI eddie;
rick
Thanks - Yes the car does shift into overdrive. And the light flashes all the while even on long journeys
