Any Info Welcome
kevbazl
ok i have a carlos sainz st-185 engine management light is on and slack on power , could this be because there is a slight crack just after the bracket on the black pipe from the air filter going into turbo, any idea how much a new 1 cost,, any ideas what else the problem is :P . this problem is result of getting new clutch fitted
54 usually point to the intercooler.
see my sig for a link to a great website for info (not mine unfortunately) the crack will be letting in extra air so i would replace it as soon as you can incase this is the case as it will lead to you running lean, don't know the price for this piece unfortunately
