Which Exhaust Is The Best?
PHILGTS
I need to replace the cat in my exhaust, and in my world anything that needs to be replaced gets upgraded. so it is time to upgrade my exhaust.
I've read that lowering backpressure improves performance, but I don't know what other factors need to be considered when picking an exhaust.
has anyone ventured into this territory that can share a little wisdom with me?
thanks so much :)
thanks so much :)
you need to make sure you get the rite size pipe other wise you will lose to much backpressue then you will loss horses! make sure you know sum1 who will give you a dodgy MOT because if you get rid of the cat it wont pass the emissions
gotcha. I immagine the companies that produce these exhausts must have taken the backpressure issue into consideration- but I still would like some input on what exhaust will improve performance
The TRD is supposed to give a few extra BHP but some Members this side of the water have paid over 600 Pounds for it!
