Oil Consumption
basharat_hussain
Hello All,
Yet another problem (maybe!)
my Y reg Toyota corolla (1.4VVTi) is consuming a fair bit of oil !
I topped up at the start of the week and then did some 600 miles in that week and at the end i had to top up again (!) I was down by approx 1/4 of the threshold levels
A problem i thought, but asking the dealer, he replied, it should do 1000km (600miles) to a litre of oil !!!!!
suprised i checked the manual and it was there in black and white !
is it normal for a car to consume so much, especially if its fairly new (2 years old done around 40kmiles)
One other observation is it is always smoking, even when its been running for 1-2 hours. The dealer said it was condensation smoke !
definately somat wrong there!
and i doubt ya gonna get vapour after a couple of hours!
rings mite have shot it
The car is still under warrant (just !) 2 months left !
how can i persuade the dealer there's summat wrong when they have the get out clause in the manual of 1 litre/600miles ?
just try demanding over an over again until they cave in and do something about it
Try a different dealer.
Or Trading Standards... All ways gets bells ringing..
I'm having some problems with Bass Junkies at the moment about my amp and sub.
They say i've blown it but i didn't even play it loud? I was still wearing in!! They changed the sub and amp over and the same happened again. Hence Trading Standards...
what is a short block (see below)?
http://www.toyotanation.com/showthread.php...&threadid=26117
Posted by Jzs147-RR:
I work at Woodland Toyota in quebec we have changed over 6 short blocks because of this problem looks like the pistons are just loose in there.I would get them to take apart your engine and get you a new short block.Tell them its a manufacturer defect and need to replace your shortblock.I am sorry to say these 1zzfe look like they have many stupid problems including changing the water pumps often and the vvti gears making noise.If you where closer i would say bring the car here so i could check it out.
Bash.
A short block is the name given to the bit comprising the engine block, pistons and crankshaft assembly, it is changed as a unit so the problems and costs involved with setting up that part of the engine are avoided.
The 1ZZFE engine sounds like it's not good as others.
do all 1.4VVTi have a 1ZZFE engine ?
mine is Y reg 2001 !
