Fixing Direction Of Windscreen Washers?
jez9999
Why do they make windscreen washer squirters that can get misaligned? You wouldn't think it was that tough to just make them work reliably.
Anyway on my Toyota Corolla, all 4 of them are squirting in the wrong direction; too high, off to one side, etc. Is there a way to fix the alignment of the windscreen washers?
You need a pin or something of a similarly small diameter and some patience.
The water jet is a ball and socket assembly, of which the ball is adjustable, but remember, a little movement on the ball translates to a large movement in water jet direction.
Let us know how you get on.
Cheers.
