Eml Light On After Fitting Induction Kit
DAVE ANGRY ANDERSON
i have a gen 7 celica 140, i fitted a induction kit on it but it came with no instructions! does anybody now wot i have to do with all the vacume pipes and the solenoids that are on the old airbox? and wot do i do to the pipe coming off the inlet manifold do i need to bloke it off?
thanks
dave
thanks
dave
I think you just need to bolt the air sensor to the intake (making sure to orient it correctly). and I believe that vacuum hose you're talking about feeds small ammout of exhaust into the intake to improve efficiency. there should be a port on the intake where you can attatch this hose. you might need to do a little fussing around with the size of the hoses and whatnot, but some zipties ought to fix any problems there.
