Avensis 99 Gls
wahidhussain
:unsure: hi all
can any one help
when i wash my car the back left wheel drum does not relese. It any happend 2 time after washing the car i thing its to do with the break drum
ive owned the for 2 years with 97000 on the clock i am going to the garage on monday
i was thinging you guys can help :unsure:
thnk you
wahid hussain
:unsure: hi all
can any one help
thnk you
wahid hussain
hello
how did you release it after washing/drying?
check with greasing of relevant parts responded to park brake.
cheers
hi igormus
thanks for your reply
i wash it on friday this happened on saturday so it took all day playing with it
after going to the garage on monday they greased it should be ok know
thank you
wahid hussain
hi igormus
thank you
wahid hussain
hi wahid
all the problem are connected with an "excessive maintenance" :))))))))))
it is life
good luck to you
Igor
hi igormus
thank you
wahid hussain
hi wahid
it is life
good luck to you
Igor
Mine had a split in the handbrake cable outer that corroded and stuck on. Have a look at the rear handbrake cable by the brake drum and see if it has split.
Tweeks
