Rear Stability. Products Inside!
ballist1x
So the corolla is a bi lose at the back end (it seems!) especially when the front is improved via front tower strut bar etc.
Has anyone tried any of the following mods;
TRD STABLIZER SET
The TRD stablizer set dramatically reduces body roll without reducing ride comfort for street driven vehicles. The reduced body roll translates into overall improved and more predictable vehicle handling during heavy cornering load.
Features
- Kit includes Stablizer Bar + Bushes
- Dramatically reduces body roll
- Stiffer than standard from 20 to 100%
- Features hollow or solid shaft design
48812-ZE200 Toyota - Corolla ZZE122/123/127/128 - Rear Only - 23mm - 49% Stiffer GB £ 73.91
C-ONE PERFORMANCE BAR
FB5229-ZE123 Toyota - Corolla - ZZE123/ZZE122G/NZE121 - Rear GB £ 189.85
C-ONE TOWER BAR
FT5361-ZE123 Toyota - Corolla ZZE12#/NZE12# - Rear GB £ 84.21
C-ONE SPORTS STABILIZER BAR
CS4883-ZE123 Toyota - Corolla - ZZE123/122 - Rear GB £ 122.62
all from nengun.com
Im going to do th front strut brace and then potentially, the rear TRD stabiliser. its pretty cheap and if it does what it says on the tin? £ performance would be excellent.
there are chassis braces from C-One but these are more expensive and a step further id day. not sure how the chassis would react if the back only was done and not the front or viceversa.
I'm interested in getting a rear strut brace but ideally want an under chassis one, don't really want to have to cut the rear trim.
That stablizer set sounds good - would it fit the 5dr T3 03 Plate hatch i've got and if so where does it fit onto the vehicle. I've had an offer for the front strut - hoping to purchase before it gets sold
as i understand it;
TRD STABLIZER SET
is an undercar anti roll bar replacement unit for oe versions.
