Hello,
I have just ordered my OZ Superturismo 15" (see earlier post) and have some questions about tyresizes.
I want to buy the 195/45 R15 but I'm a little bit afraid that I will feel every bump in the road.
Anyone driving with the 195/45 tyres? How does it feel? Does it change the comfort very much negative?
Is it possible to use 195/50 or will that wont go with the wheelarch?
Or maybe 185/55? Or will that also not work?
Please help..
- Joel
Yes, you will feel every bump in the road.
Comfort = negative, handling = positive, looks = positive.
Yes, it's possible to use 195/50 but that will scrue up the spedometer and the ODO. The best fit is 195/45 R15, it's ~ the same diameter as stock.
Conclusion: use 195/45 R15. Many have it. Everybody is happy with it, and so will you :)
The only other option that retains the standard rolling circumference is a 175/50 R15 but as far as I am aware only two tyre companies produce a tyre that size
Anyone knows if 185/55 15" will fit the Aygo?
Please help :unsure:
/Joel
