:( i have had a new verso sr diesel for 8 monthes covering 8k miles.
So far had discs replaced because of scoring, rear shocks replaced due to leaking,wheels re-balanced due to balance weights droping off.
Now i have a rumble on the front end,the dealer said that the wheel bearings are failing and will be replaced under warranty.Is this a known issue as the dealer said its the first they have seen.This is very worrying for reliability.
i have a 07 Verso the only thing a had replaced by my dealer are the rear discs cause in 1 of them was a groove in de middle , i bought it from a dealer as a Demo with 4700km on the clock last March ( 15e) and now i have 13000km on the clock
All my Discs need replacing on my 2.2d SR Feb 2008 model). Which dealer are you using? I'm using Listers at Stratford. I will ask them to check the wheel bearings. Are your Chrome wheel nuts rusting? Some of mine are and they have agreed to replace them, after much complaining.
