Will It Fit
bridgy
hi does anyone no if my wheels will fit straight on or will they need spacers the tyre size is 205/40/17 and there going on a corolla e10 also will it make a big difference if i replace the mid-section with a bit of normal staight through exaust pipe
thanks
bridgy :unsure:
I dont know the settings for your car but for anyone else to tell you the wheels will fit will need to know the PCD size,
This is the centre size relative to the wheel nuts which on Celica's is 100 (PCD 100) and the offset which I also think is the distance from the centre before the wheel curves in and provides caliper clearnace, again on the Celca it is about 38 so to size the wheel for me it is
18 Inch 225 x 40 tyre on wheels that are 18, PCD 100 by 44
To learn more about wheel sizing check here Wikki
Then get the data for your wheels and your car......Sorted!....or
are you asking if the wheels will fit the hub, or will the wheels and tyres clear the arches. I imagine they are 15 inch standard?
