Help Fitting In Bluetooth Mic In Celica Gen 7
bond4uin
Hey guys,
I just bought a pioneer head unit with bluetooth facility. I have fitted the system in but am really confused on how to put the mic in there. Ideally i would want it to go on the driver right hand top side. But dont really know how to take it there or dismantle the trim. Any help will be much appreciated.
Thanks in advance.
Hey guys,
Thanks in advance.
I would run it under the driverside plastics, and up the drivers side a pillar, then under the roof lining, to appear where the map light is.
all these panels can be removed by being pulled off... i think there may be a screw or two under the drivers side plastics.
Thanks alot mate. That was quite helpful. Finally i fitted my stereo quite neatly. For all those who have questions on fitting the stereo in and fixing it, lemme know, in the past few days i have literraly learned everything about the audio for the celica. lol. Even got detailed diagrams
Didnt get the pioneer FH-P80BT by any chance? i just installed mine the other day too, was really easy....but am also finding it difficult to place the mic!....if u manage to do it then lemme know :)
Thats the 1 mate.lol. Wot i basically did was, after installing the headunit i pulled out the driver side a piller. Basically u just open your door, pull back the rubber surrounding and push it back, its just held in place with clips. Then take out the 2 bolts underneath the sterring wheel with a number 10 wrench (cant really rememba the right word for it).
Wot i did was clipped my mic on the sun visor, and then took the wire from the a piller and then under the steering wheel and then at the back of the head unit.
Hope this helps.
(P.s the head unit is awesome, especially the bluethooth, voice is crystal clear on both sides)
There's a liitle space for a bluetooth mike just inside and to the right of the head unit area. Its around the area your left knee would be. Have a look , you''ll see a tiny grill there
