Yaris Sr Mp3 Music From Usb
Spurs
Hi, has anyone else had the same trouble as me ? I downloaded my music onto my memory stick, in MP3 format, and this worked fine for a few days.
However, I now find that the music loads onto the TNS400 but does now not play.
Anyone got any ideas ????
I had the same problem,one minute it would play the next it wouldnt.I think it might be to do with the application software on the s.d.card.Mind you my first s.d card on which i had the problem, corrupted and since ive had a new one and updated the application software ive had no trouble.
there is a new sd card and stereo firmware update available from your dealership.
it will all be done under warranty too :D
Mart.
sounds to me that you have pulled the memory stick out before pressing the eject button on the screen . if this is what you have done then it may have wiped some folders from your memory card in your sat nav . these folders are in the (bin) folder on your card
Yeah , thanks. Looks like you're right, the 'bin' folder is empty. Is there any way of correcting this that you know of ??
I'm also having problems playing mp3's using a USB stick. I download music onto the stick (approx 5Gb) but when I play it only some of the folders can be played. When I check the USB the missing folders are still there. Is there a limit to the number of tracks that can be indexed (mine seems to only recognise 700 ish) or is there a maximum capcicty usb stick that can be used - I have a 16Gb one at the moment. BTW - the stereo haz had the upgraded software and new SD card.
Any help gratefully received.
