Baby Seat And Airbags
shamz
Hi All,
Wanted some advice. I bought a car seat for the baby (rear facing) and was advised to disable the airbags. On my corolla 1.6 (2005) there is a switch that disables airbags. Question is there are airbags on the doors etc..I do not know if these get disabled. Where can I find out?
S
It is usually only the front passenger seat airbag that has to be disabled and only if you are using that seat for the child car seat.
Each manufacturer works in a different way. Citroen Give you a key slot that you can turn the airbag on and off with. Mazda make you buy their branded child seat as it has a transponder in it that disables the airbag when the seat is in place (the airbag is normally activated by a pressure sensor in the seat).
My Verso has pressure sensors in the seat to activate the airbag, so I would guess it works the same as the Mazda system and you have to buy a Toyota branded seat to disable the airbag ( I could be wrong though).
