Granvia Rear Cooler Fans
victormatt
hi has any one got any idea what could be wrong with my rear cooler fan, as it just wont work, the light comes on in the front control panel but the fans dont blow any ideas would be good thank you
I don't have a Granvia but electrical problems just require a bit of logic. For the fan to turn you need a working fan units and power. Get youself a test meter and the unplug fan power connector and with the switch on see if power is getting to it. If so then the problem lies with the fan if not check the fuse associated with this circuit. If the fuse is ok then you either have a broken connector or if this fan is part of your climate control then it could be the rear thermal sensor.
