hi has any one got any idea what could be wrong with my rear cooler fan, as it just wont work, the light comes on in the front control panel but the fans dont blow any ideas would be good thank you
Hi there. I had the same problem on my Granvia. I got some good help off the Granvia Forum, which doesn't seem to be around anymore, photos showed the relay found behind/under the passenger's airbag. When you locate it, open it up and clean the contacts. It was simple to do, just hard to find. It got all the rear air con up and running immediately.
hi kaila thanks for your help but could you tell me what the relay looks like as i had a look where you said but i could not see a relay there were just wires and plugs, do you think you could send me a photo of it please, thanks again for your help
