Don't know when or how but I have to steer quite a bit right to be going striaght, if I leave it straight it veris left immediately.
Do I have to contact MR. T about this, is it going to cost me, is it going to be free under warranty etc?
Has it been like it since new? Checked your tyre pressures?
Maybe you have kerbed or potholed it.
I think that you may have to pay to get it sorted but you can only ask to have it done under warranty
Left brake caliper could be seized too, but unlikely.See if the disc is hotter than the right hand one after running.
Mr T would probably want to do a 4 wheel alignment which I was quoted over £50 for, so I took it to a local specialist who reset the track for £15.
If they wont do it under warranty ,I would thank them for their time and go elsewhere.
you can get a free VSR (vehicle safety report) done on it - if they find anything wrong with it ie sticking calipers etc then these will be sorted under warranty (as long as its still in warranty)
if they find nothing and it just requires tracking you wont get this under warranty.
Mart.
Has this happened on the M1? Cos if so mine was doing the same, but it was due to the high crosswinds, especially between Moira and Lurgan!
Mine did this after new front tyres and 4-wheel alignment; I was going to take it back to have it looked at again (it had been fine before taking it to the garage) but then decided to check my assumption that the garage would inflate the tyres correctly - they hadn't: one was at 28psi, the other at 34psi. Well done HiQ (£50/corner inc. fitting/disposal/etc. cheapest around here though).
It happens eveywhere all the time. ill get it checked. Wont be for a while though, had my hernia operation on tuesday there. Will be next saturday prob at the earliest before im in the car. And first place im goin is the car wash its covered in bird !Removed! grrrr
