Multi Amp
vmail
hi, is there an Amp that can Amp the Sub, 6*9 and door Speakers only using 1 Amp, are there any disadvantages?
Which amp can do this?
yep look for a 5 channel amp
they are exactly what you just asked for, can run a set of fronts, rears and a sub from one box
sorted
:thumbsup:
what am I sending to the amp?
rear RCA for the SUB(amped)
front RCA for the door(amped)
rear channel for 6*9(amped)(only have connected RCA for amp, are normal channels different)
front channel dash(un amped)
you mean you have two RCA outputs from your head unit??? (let me get that straight first!!)
most 5 channel amps only need 1 RCA input but will take upto 3.. 1 for the bass the other 2 for the Speakers.
yeah headunit has 2 RCA (front and rear) + 4 standard channels
ok then
as a suggestion you could use the alpine v12 5 channel amp, sorry cant remember the number exactly mrv-f450 i think??? check CEL for it. its about 250 quid but its a good amp
the way to do it would be thus
front RCA leads to front channels on amp for front Speakers
rear RCA leads to sub channel for sub
and i think this amp is capable of this, ill have to check, but run a high level input to it for the rears (the normal stereo output wires) because the amps have the option to run off high level instead of using RCA (ie if you want to use an amp with an OE headunit)
:thumbsup:
just looked it up and the mrv-f450 has high level iput capability so you would easily be able to do what i said before.
the only thing about this one is it doesnt kick out a huge amount of power. your lookin at spendin more for a more powerful amp, but youll still have one hell of a sweet and compact full system
:thumbsup:
