Fmic
ajcluck
Hi all, i was wondering if anyone knew how good the cores off eBay were? i am looking at one that is for an evo 5 and was going to buy a universal pipe kit? can these cores be trusted and will they be ok for my gt-four?
best bet is the pulsar GTiR kit from D2 powerlink here
good quality core and the pipe work can be made to fit the celica quite well . i have it fitted to the rolla.Toyota-Corolla-3SGTE-Engine-640.jpg
makes for a neat install, recommend 'clocking' the turbo for best fit. you will need a few bits of samco to complete it (a length of 63mm straight, a 63 mm long 45degand a 63mm 90deg reducer (to fit onto the turbo)) thats based on the turbo being clocked.
cheers buddy, will go and order that, you mite be able to advise on an other few things, i have my ct26 turbo on eBay, how much should i hold for? and what turbo should i replace it with? looking at getting 500bhp!
see other post regards tubby.
as for the second hand value any where between £80-£150 for a standard one with normal miles on
