Alloy Wheel Studs
bilun777
Looking to replace the steel wheels on my rav4.1 .Do I have to replace the steel wheel studs If so how? thanks in anticipation. :) :)
Just leave the wheel studs! Make sure you get wheel nuts with the alloys that are compatible with both the wheel and the studs.
I've had the same studs on my RAV and have 3 different sets of alloys for it; and have 3 different sets of wheel nuts for each wheel set.
If you want to be particular, ask the alloy wheel supplier what torque the nuts should be done to. Whatever, each nut should grab at least 4 threads on the stud.
Thanks for that, all I need now is aset of alloys[back to ebay] :)
