Help! Gt-4 Needs Bushes
bates374
i need some help asap!! just had my beloved GT-4 (st205) on the ramps at work and although its not gleaming underneath its not too bad for her age,
but... i fount a couple bushes that are a little more than sloppy!
i have searched every possible source to get hold of some but to no avail! not even powerflex do them,
they are the front lower sub assembly No2 bushes, left and rigt side,
now im a mechanic so i have all the equipment to replace them myself,
Fensport do the whole arm but they aretrying to pull my pants down at £226 a side +VAT!!!
so please help me, MOT is up soon an i know theywill pick it up!!
any help will be greatly appreciated
cheers
if you mean the lower arm bushes then Nope. pants down time.
keep an eye on eBay or if you need them in a hurry TCB or wiffbits
time to pay up, should last 60k miles though
doubt it will be picked up on mot as all the links support eachother
Hi, Did you have any joy in getting hold of some bushes, I have a ST202 and need to get hold of some too. I have also checked eBay and cant find any. Did you have any luck? If so, can you advise where from?
cheers
the bushes he required were in the chassis of the banana arm , ie - crush tube - the st202 front arms are completely different. the st202 has wishbone arms ,these arms from toyota are in excess of £200 each
