Clutch Judder Hi Lux 2.5 D4d
I OWN A TOYOTA HI LUX HL3 2.5 D4D YEAR 2007 WITH 2338 MILES ON THE CLOCK. I HAVE BEEN EXPERIENCING CLUTCH JUDDER FROM COLD, IT IS NOW GETTING WORSE WITH MILD JUDDER WHEN WARMED UP.IHAVE HEARD ABOUT FAILURE OF DUAL MASS FLYWHEELS WITH THE SAME SYMPTOMS SHOWING UP. ANY ONE ELSE COME ACROSS THIS, BEARING IN MIND THE LOW MILEAGE.
my 05 d4d hilux developed a clutch shudder and noisey thrust bearings Toyota NZ replaced the complete clutch which fixed the shudder but the thrust bearing became noisey again, it ****** me off so much i bought a auto hilux
Mine did this at less than a year old and clutch was swapped.
Less than 2yrs old now and its doing it again intermittently.
I have a Toyota Hilux 2,5 D4D XTRACAB SR5 / KDN 170L -2003 and have experienced the same sympthom. But only when cold and even not always, but I'm a little worried anyway and havent so far managed to find out the reason.
