Avensis 2000 G/box Woes
elabbs
Hiya,
my 2000 toyota avensis 1.8 vvti has coverd 193,000 miles. everything is great except the gearbox is now noisey in all gears.
i was going to drain the oil, as i summize its never been changed and then add some molyslip gearbox additive along with fresh oil.
am i wasting my time.? or do you think that it could quieten the box a bit.
if i have to change the gearbox what kind of a job is it, im reasonable at engine changes and stuff so im not too worried , just wondering how bad it is to change.
Does anyone have a box i could buy off them ...?
and just to finish my post , the engine management lights just come on. everything is running fine, no problems at all. how can i reset the light as its constantly on.
thanks
Andy
Hiya,
thanks
Andy
I doubt an oil change will help on this gearbox - its usually the bearings wear ecxessively which then leads to wear in the gearbox case itself.
Mart.
