Rain Water Under The Carpet
smily
My avensis 04.Rain water coming from some where under the carpet of front passenger seat.Its only happen when is raining.Any one any idea where it is comming fron.(this car has no sunroof)Any suggestion/ will be very much appriciated.thanks
Well as you say this only happens when it rains it might not be the cause but damp carpet is usually caused by a blocked A/C drain pipe, and since it's more humid when it rains the A/C would remove more moisture from the air therefore making the problem worse when it rains.
Thanks for your suggestion.but it is not Ac I got it checked.it is rain water cos when raining it is lot of water under the carpet passenger side.on dry day I have poured the water from roof but cant see water running down.thanks
