Disconnected Battery And Immobiliser
Bartek
Ive dissconected my Battery and since then, my alarm dont react on my key fob.Ive been trying many solutions taken from thys forum...like Disconnect Negative Battery terminal leaving positive connected.
(Make sure drivers window is down as car may lock)
 Put key in ignition and turn on, Leave on.
 Reconnect Battery terminal.
 Switch off ignition and remove key.
 Press black button and hold for ten seconds.
 Alarm should work.
and fiev differend ideas,but none of them worked.My car is Toyota Celica GT L reg. import from Japan with AUTOWATCH alarm.
Does enybody have a right solution?Help
p.s i know how to start my car becouse ive found the way to cheat the alarm and the immobiliser.But i want my alarm back.
