St202 Exhaust Woes
J&A
My daughters' St202 is in dire need of a front pipe for her exhaust but so far we've drawn a blank. Any ideas or suggestions would be REALLY welcome. Thanks.
Thanks for the rapid response. Unfortunately it's not the manifold that she needs (my explanation was probably crap). The problem originally arose (we think) because some drongo with an oxy torch got carried away trying to loosen the front bolts when fitting a replacement cat. As a result he totally knackered the joint, meaning that she not only needs a new catalyser (not too much of a prob to source), but a new front pipe as well. By front pipe I mean the part of the exhaust that joins the manifold to the cat. Suppose on reflection it would have been better to call it a downpipe! Whatever it's called, it's as hard to find as a Derby County victory- and that's hard! Still looking for suggestions, sources etc.
Cheers
Why dont you contact a firm like exhausts UK based in Sheffield in see if they will fabricate one for you?
