Yaris Stutter
daveyravey
Hi everyone, what a great community.
My name's Dave and I have a 1999 Yaris SR 1.3. I was moved to look under the bonnet at the weekend for the first time in 5 years mainly by a weird stutter that has occurred over the last 6 months.
When applying foot to accelerator after an idle at lights or whatever the engine is slow to respond and seems like it will stall. I have read many posts here highlighting similar problems and have done the following after advice from here.
Checked air filter
Cleaned the MAF
Cleaned all connections around air pipe
Put in new spark plugs
Is there anything else I can do that anyone can think of?
Cheers
Dave
Checked air filter
Cleaned the MAF
Oil and water :thumbsup:
Checked air filter
Cleaned the MAF
Cheers
Dave
Replace the driver??............ ;) :P :lol: Do some maintenance :rolleyes:
Have you checked the connections on the coil packs for tightness and corrosion?
Because you said "I was moved to look under the bonnet at the weekend for the first time in 5 years".......................dont you lift the bonnet to service it?? :rolleyes:
and "mainly by a weird stutter that has occurred over the last 6 months".......................why did you not do something as soon as the stutter occured?? :D
You should not ignore any warning signs :)
