Removing Stone Chips?
kangzy
how do i remove stone chips guys?
or where can i get it done? how much? quality of the job?
cheers shaun
I got a touch up kit from Mr T.
Spent hours sorting them only for more to appear!! :lol:
I think you have 3 options:
Touch up stick + T-Cut £20 - This all depends on how good/brave you are with paint and cutting paint back and how much time you can give it
Chips Away £80 ish - I have had good experience with these type of people, they would blow the bonnet in and blend
Bodyshop £500+ Paint the bonnet and blend into the wings
Hope this helps :thumbsup:
but is easy to do it yourself? and did it match and blend exactly? cost of the paint?
reason y i asked is because im going to "tint" my front bumper with a protective see through plastic to stop it happening again lol!
Exact match but it does take a few coats to build it up to the same level as the existing paint work.
Think the touch up kit, which is paint & lacquer was around £5 :thumbsup:
chips away?? let me look into it? is 80 a general price or does it depend on the extent of the work that is needed?
They would typically charge that for a bonnet, however its been a while since i had any work done, so with inflation etc don't quote me on the cost :thumbsup:
haha...i guess im in for a suprise then!
