Maximum Boost
Hi guys first post here
i have a 1993 mr2 turbo jap import
mods as follows
Blitz dual solenoid digital boost controller
blitz turbo timer
Walbro 255 fuel pump
sard fuel pressure regulator
4 inch core intercooler
exedy redbox clutch
stainless exhaust system]
Hks cone filter
Turbo smart dump valve
I was wondering given the modifications how high i can run the boost on the highest setting
could you leave comments in Bar. please and any other advice would be much appreciated
is it a Rev2 or Rev3 (1993 could be either)
if Rev2 then 1 bar, Rev3 1.2 bar unless its a Rev2 with uprated head gasket :)
TBH id wouldn't go higher than 1.1 on a rev 3 or 1,0bar on a rev2 with MHG unless a re mappable ecu is fitted.
don't fit a FCD as it will only lead to tears and broken pistons
