How Much For That G6r In The Window
rayzer
hi pple,
can anyone advice me on how much I should put my G6R up for in the local press for sale, .. black and in perfect running condition with below average mileage.
all advice welcome.
ta
£2000 (tops for perfect example) and NO MORE!
Also check handbrake/rear brakes are working correctly (also not to much build up of corrosion on rear brake discs).
And if car has done around 60,000 mile or more check when stationary that it 'idles' okay (not fluttering) if so Oxygen sensor/Lambda Sensor may need replacing -easy job but genuine one is around £90!
Good Luck
