Immobilisers Won't Disengage
si709
Hia
After not running my 2001 Y reg celica for a while, i discovered i'd got a flat Battery, after re-charging, the engine will turn over but not start. Been tld this is because the immmobiliser will not disegage after a flat battey.
Does anyone know if this is true, and if so how to fix it without a trip to the dealer?
any help would be appreshated
Thanks.
Ive had same problem.No body gave me an answer on my question on many forums,and not only english.My immobilliser is still not worknig but i know how to start my car.Ive found the fuse under the steering wheel.Im taking it out, turn the ignition key to start position and holding, than plug the fuse In and engine starts.
you need to teach the fob to the alarms wavelength , for the gen 6 its on this forum under user name " sotal" not sure on gen 7 it maybe a dif alarm ??
http://toyotaownersclub.com/forums/index.p...showtopic=50803
