Passenger Door Panel
chard
Hello all,
I have an '05 T3S Avensis, the electric window in the passenger side door seems to have come off its runner. I have tried to remove the panel and have so far located two screws. One by the door handle and another inside the electric window switch casing. I am pretty sure that therer is at least one more screw to remove. Can anybody tell me where it is and how to get at it.
Many thanks in advance.
You have a screw behind pop-out trim which covers hole in trim for fuel release button if car was left hand drive. Remove trim & look upwards at slight angle & you will see 10mm bolt holding door panel. Remaining fixtures are just plastic push in buttons around door panel.
Thanks for the advice mate, its the one behind the fuel button trim that I cant get to. What tool would you suggest as it seems to be a couple of inches from the hole itself.
Again many thanks.
Best tool is a 10mm socket on a 1/4 drive or 3/8 drive exst bar with ratchet. You do have to look up at a slight angle to access screw.
  • Topics
  • Our picks
        • Like
        • Thanks
        • Like
