Cruise Control Installation Instructions
7 hours ago, Terppa1985 said:
Hi Folks!
I have an Auris 2007 and engine is Dual VVT-i 1.6 Petrol (1ZR-FE). Is anybody installed this cruise control on that type of Auris? Is it working? Second questions is, if it´s working, where I can get the needed equipment?
Thanks in advance
Br, Tero
Yes, I have (just like many others :) ). You can get the CC lever from eBay. The 2007 Auris with 1ZR-FE is really easy to install - it's plug and play.
1 hour ago, Auris 1.6 vvt-i said:
Yes, I have (just like many others :) ). You can get the CC lever from ebay. The 2007 Auris with 1ZR-FE is really easy to install - it's plug and play.
Thanks for fast reply! I found this at Ebay http://www.ebay.com/itm/Cruise-Control-Switch-8463234011-for-Toyota-Camry-Corolla-Tundra-Lexus-Screws-/261828486695?hash=item3cf631a627:g:gj4AAOSw7aBVFtIm&vxp=mtr is it compatible?
Rgrds, Tero
15 hours ago, Terppa1985 said:
And I found this on toyodiy.com
Quote
Part 84632-34011 (SWITCH, CRUISE CONTROL MAIN) was found on the following models:
  Date range Model Frames/Options Found in diagram
  08/2011- TOYOTA YARIS KSP130,NSP130 84-08: CRUISE CONTROL (AUTO DRIVE)
  11/2010- TOYOTA VERSO-S NLP121,NSP120 84-08: CRUISE CONTROL (AUTO DRIVE)
  10/2001-09/2006 TOYOTA COROLLA CDE120,NDE120,ZZE12* 84-08: CRUISE CONTROL (AUTO DRIVE)
  09/2002-09/2006 TOYOTA COROLLA CDE120,NDE120,ZZE12* 84-08: CRUISE CONTROL (AUTO DRIVE)
  11/2001-01/2007 TOYOTA COROLLA CDE120,NDE120,ZZE12* 84-08: CRUISE CONTROL (AUTO DRIVE)
  01/2002-01/2007 TOYOTA COROLLA CDE120,NDE120,ZZE12* 84-08: CRUISE CONTROL (AUTO DRIVE)
  02/2004-01/2009 TOYOTA COROLLA VERSO AUR10,CUR10,ZNR1* 84-08: CRUISE CONTROL (AUTO DRIVE)
  11/2006-03/2013 TOYOTA COROLLA ADE150,NDE150,NRE150,ZRE151,ZZE150 84-08: CRUISE CONTROL (AUTO DRIVE)
  02/2008-05/2013 TOYOTA COROLLA ADE150,NDE150,NRE150,ZRE151,ZZE150 84-08: CRUISE CONTROL (AUTO DRIVE)
  10/2006-07/2012 TOYOTA AURIS, COROLLA ADE150,NDE150,NRE150,ZRE15*,ZZE150 84-08: CRUISE CONTROL (AUTO DRIVE)
  02/2007-04/2013 TOYOTA AURIS (HYBRID) ADE15*,NDE150,NRE150,ZRE15*,ZZE150,ZWE150 84-08: CRUISE CONTROL (AUTO DRIVE)
  08/2003-02/2009 TOYOTA PRIUS NHW20 84-08: CRUISE CONTROL (AUTO DRIVE)
  04/2009- TOYOTA PRIUS ZVW30 84-08: CRUISE CONTROL (AUTO DRIVE)
  12/2009-09/2010 TOYOTA PRIUS (PLUG-IN HYBRID) ZVW35 84-08: CRUISE CONTROL (AUTO DRIVE)
  05/2012- TOYOTA PRIUS (PLUG-IN HYBRID) ZVW35 84-08: CRUISE CONTROL (AUTO DRIVE)
  03/2012- TOYOTA PRIUS, PRIUS + ZVW40 84-08: CRUISE CONTROL (AUTO DRIVE)
  12/2010- LEXUS CT200H ZWA10 84-08: CRUISE CONTROL (AUTO DRIVE)
  08/2005-03/2013 LEXUS IS250/350/2xxD ALE20,GSE2* 84-08: CRUISE CONTROL (AUTO DRIVE)
  12/2007- LEXUS IS F USE20 84-08: CRUISE CONTROL (AUTO DRIVE)
  04/2009- LEXUS IS250C GSE20 84-08: CRUISE CONTROL (AUTO DRIVE)
  08/2001-12/2005 TOYOTA CAMRY ACV3*,MCV30 84-08: CRUISE CONTROL (AUTO DRIVE)
  01/2006-08/2011 TOYOTA CAMRY ACV40,GSV40 84-08: CRUISE CONTROL (AUTO DRIVE)
  08/2011- TOYOTA CAMRY (HYBRID) ACV51,ASV50,AVV50,GSV50 84-08: CRUISE CONTROL (AUTO DRIVE)
  01/2005-11/2011 LEXUS GS30/35/43/460 GRS19*,URS190,UZS190 84-08: CRUISE CONTROL (AUTO DRIVE)
  02/2006-11/2011 LEXUS GS450H GWS191 84-08: CRUISE CONTROL (AUTO DRIVE)
  05/2001-11/2009 TOYOTA AVENSIS VERSO, PICNIC ACM20,CLM20 84-08: CRUISE CONTROL (AUTO DRIVE)
  02/2003-11/2008 LEXUS RX300/330/350 MCU3*,GSU35 84-08: CRUISE CONTROL (AUTO DRIVE)
  12/2008- LEXUS RX270/350/450H AGL10,GGL15,GYL1* 84-08: CRUISE CONTROL (AUTO DRIVE)
  03/2005-11/2008 LEXUS RX400H MHU38 84-08: CRUISE CONTROL (AUTO DRIVE)
  02/2000-12/2005 TOYOTA PREVIA, TARAGO ACR30,CLR30 84-08: CRUISE CONTROL (AUTO DRIVE)
  01/2006- TOYOTA PREVIA, TARAGO ACR50,GSR50 84-08: CRUISE CONTROL (AUTO DRIVE)
  05/2000-10/2005 TOYOTA RAV4 ACA2*,CLA2*,ZCA2* 84-08: CRUISE CONTROL (AUTO DRIVE)
  11/2005-11/2012 TOYOTA RAV4 ACA3*,ALA3*,GSA33,ZSA3* 84-08: CRUISE CONTROL (AUTO DRIVE)
  12/2012- TOYOTA RAV4 ALA4*,ZSA44 84-08: CRUISE CONTROL (AUTO DRIVE)
  07/2005-03/2012 TOYOTA HILUX KUN15,2* 84-08: CRUISE CONTROL (AUTO DRIVE)
  07/2011- TOYOTA HILUX KUN2*,35 84-08: CRUISE CONTROL (AUTO DRIVE)
  09/2002-07/2009 TOYOTA LAND CRUISER PRADO GRJ12*,KDJ12* 84-08: CRUISE CONTROL (AUTO DRIVE)
  08/2009- TOYOTA LAND CRUISER PRADO GRJ150,KDJ15* 84-08: CRUISE CONTROL (AUTO DRIVE)
  11/2009- LEXUS GX460 URJ150 84-08: CRUISE CONTROL (AUTO DRIVE)
  01/1998-07/2007 TOYOTA LAND CRUISER UZJ100 84-08: CRUISE CONTROL (AUTO DRIVE)
  01/1998-07/2007 TOYOTA LAND CRUISER HDJ100,UZJ100 84-08: CRUISE CONTROL (AUTO DRIVE)
  09/2007- TOYOTA LAND CRUISER URJ202,UZJ200,VDJ200 84-08: CRUISE CONTROL (AUTO DRIVE)
  08/2002-07/2007 LEXUS LX470 UZJ100 84-08: CRUISE CONTROL (AUTO DRIVE)
  11/2007- LEXUS LX570 URJ201 84-08: CRUISE CONTROL (AUTO DRIVE)
Order placed from eBay. Hopefully everything goes well :)
Hmm, yesterday arrived the shipment from eBay. It looks that the cover from below is not compatible. Is it the only "nice" solution to drill an hole and insert the grommet? See the enclosed attachment.
Br, Tero
I replaced the wheel cover with one, that has a CC hole as I wasn't very fond of the drilled/grinded DIY look.
I have cc fitted by dealer, and there's just round hole drilled, no grommet or anything. It looks fine, at least in my opinion.
What is the part number for that cover?
Do you have an picture of that installation?
Search the topic - I have given the part number twice, including in the last couple of pages. I don't have a picture.
Here's one taken today https://www.dropbox.com/s/5azp295hqr6yjh3/IMG_20160503_113226.jpg?dl=0
You can't see the hole unless you look behind the wheel, since the front of the wheel is larger that the back where the hole is.
On 08/09/2008 at 9:14 AM, Parts-King said:
The switch and cable come to £72.44 delivered to any UK address, overseas will be higher
Are you saying that the Cruise function is already on the car and you just need these two parts to enable it? If that is the case it seems a remarkably cheap cruise control. I am sceptical :rolleyes:
Kingo :thumbsup:
this is also true on the lexus CT200h buy the same parts ,switch , cable ,2 screws & switch cover then its plug & play ans the jobs done
If you don't have the cap as shown in picture 4 on the steering wheel surround, are you supposed to cut a hole out?
do you have a picture? i need to do this to mine
the hole looks awful,if a cover is available it will come with a piece of thin rubber attached to the rear
of the cover this is to stop dirt & dust entering the steering wheel.
the rubber dust cover has cuts going from the centre to the corners so it doesn't restrict the movement
of the stalk.
Hello im installing cruise control to my corolla 2005 and i have a problem. When i push the on/off button the cruise light in the dash turns on then push the lever down (set) nothing happens.
I dont have the clutch switch and i think thats why it dosent work. I havent found the wires for that switch so if somebody could help me to locate these wires that would be awesome.:biggrin:
i cant help anymore as i have only dealt with cruise on a cvt transmission but i am sure another member will be able to help you
I've done this to my car and used a £11.99 cc stick from Amazon. Took a gamble as the Amazon page didn't state it was for the Auris but it was identical to it so figured it should work (The circuit board in the cc stick is after all very very simple!)
Anyway haven't had a single problem. I did have to drill a hole and shape it with my file set in order to get the stick in which may seem a bit daunting to some people but just take your time and work it away bit by bit. Make sure to masking tape off all areas around it where you don't want plastic filings going in.
  • 2 months later...
Hello guys!
I have recently purchased a used Toyota Auris 2011 1.3 101hp. I am very pleased from the car. Yesterday i bought a cruise control kit and tried to install it. I opened the airbag pushing the two side bars to release it and i connected the cruise control to the socket existed.Without closing the wheel drive since i had to drill a hole on the side for the stick i tried to start the engine. The car started but the rpm got low and the engine went off. Tried it for a couple of times but didn't work the same again and again. During the order of the engine i didn't see any cruise control notification on the dash while i was pressing the on/off cruise control button. So i decided to close the airbag again without installing cruise control.The same thing was happening on engine start,the rpm got low and went off till i pressed the clutch and brakes the same time and engine started normally. Can anyone help me please? Thank you very much!
As far as I'm aware the ECU on the 1.33 won't accept cruise control.
I had a look on my dash and there is no cruise control light.Is there any way to program it so it can accept it?
Not as far as I'm aware.
for  2013 HYBRID Auris and  2014 HYBRID Auris
you can contact my
I have the cables to finish the job
gianluca@comana.it
  • 4 weeks later...
Hi, I have an 2014 Auris Hybrid. I'm trying to remove the airbag but I'm not getting anywhere. I'm using the method seen in this video. I can't feel any clips/springs being released. What am I doing wrong?
