Cruise Control Installation Instructions
Hi everyone,
i have been trying the cruise control install on my 2014 Auris (zwe186 engine) but cant seem to get it to work.
perhaps i am missing some wiring, i dont know if it should be plug and play.
can anyone tell me what connector and pin(s) i have to look at to make sure?
thank you so kindly.
On 7/7/2019 at 10:28 PM, Duran said:
Hello, I have a 2007 Auris 1.6 petrol and I would like to install the CC. Searching on ebay after the parts no mentioned on page 1 (8463234011) shows many results, but when I use the ”compability function” none of them seem to fit my 1.6.
Could anybody please link me a fitting one? (I live in Sweden btw so one with low shipping cost please).
Thanks!
I ordered one on chance and I can confirm that it doesn`t work on my 2007 Auris 1.6 petrol. I get the cruise light in the dash to turn on, but no function.
  • 4 weeks later...
Hi guys, I've ordered the cruise control stalk but I'm struggling to find a seller of the cover: 45186-02130-B0. Does anyone know where I can get this part?
toyota they are less than £10
Just been advised by my local garage who contacted a Toyota specialist, and got told that my hybrid wasnt able to add cruise control to the car without possible risk to software and or engine, has anyone fitted one to a hybrid with success and how? Thanks
I have
I followed the video I shared on page 30. Literally plugged it in, it worked. Sounds like your garage is talking ****, or they just don;t know and couldn;t be bothered to look for you. Since you're in cumbria, you have a UK model, it should be the same as mine
But depends which model Auris you have, your profile says 2011. I think that's the older model. so results may vary
18 hours ago, regraham said:
I have
My garage took the advice off another toyota garage (not dealer) due to them not having the experience of dealing with this situation and headed to their advice. My model is the first Auris model and the fitting instructions on page 30 dont match my model of car.
On 6/14/2019 at 7:06 AM, Andronachescu Liviu said:
Hello,
First of all I apologize for mistakes, English is not my language, I am from Romania.
Own a hybrid Toyota Auris, manufactured at the end of 2012 and finally yesterday I managed to make the cruise control function.
I will write here what it is about because I did not find the complete answer here.
After installing the cruise control command, the damage occurred p0571.
in my case I was missing a wire between the brake pedal switch and the ECM.
the ECU plug is A130, the pin 7 that connects to the A124(switch pedal) plug, pin 5.
I hope it is clear and useful,all the best!
I have the same issue with hybrid 2013 (error p0571 and check crise control message), as far as i understand i have to connect the number 5 pin from brake switch with nuumber 7 from ECU in order to make it work? Any help appreciated
Hi people,
I have a 2016 plate auris 1.2turbo.
Can I retro fit the cruise control? When I go to buy a stalk it says it isn't compatible? Cheers 👍
Hello! I'm thinking to install cruise to my hybrid auris and didn't found if this was asked before, but does the cruise control switch have any differences if it looks the same? Asking because i found used steering wheel with cruise control on sale, and thinking to buy it just because it have cc and other parts i may need. The steering wheel is from petrol manual, but i have hybrid (without CC) . Both, my Auris and "donor" (1ZR-FAE) are -12 models.
So, will it work, and is it going to be plug & play? (and maybe adding two wires i read on the forum)
Thanks for answers!
Thanks for answers!
E150
10 hours ago, TBros said:
E150
E150? Please elaborate.
1st generation 2006-12, 2nd generation 2012-18 is E180
  • 2 months later...
On 11/18/2014 at 2:24 AM, HARDO421 said:
As stated above its to be fitted to a yaris.
Also the auris i have fitted cruise to doesn't have access panel on steering wheel but still works perfect.
How to fix in Yaris 2016 Automatic Transmission.
  • 2 months later...
Dear I have Toyota Corolla XLI 2010 I want to install cruise control kit please help me thanks.
Engine is 3zz
  • 4 weeks later...
Dear all, I have just myself installed cruise control on pre-wired toyota vios 2019. When turn it on, the symbol of CC displayed on the board, but the setting doesn't work. What's wrong with it? Please let me solve this. Thank you!
  • 2 months later...
On 9/30/2013 at 12:27 AM, mbuckiunas said:
2009 year, Engine: 1ND-TV
I have the same model, 2010 year.
Does anyone has anything to suggest? ot it is imposible to install the cruise control?
I have already place the stalk, the wire connected but nothing works.
1.4 diesel and 1.4 petrol engines are not compatible with cc.
You have to buy an aftermarket cc kit with actuator.
  • 3 months later...
Hello,
I have a 2013 Auris Icon 1.6 , will cruise control work? If so can someone please list me the part number.
Thank you.
I have a 1.6 vvti and can confirm it works.
I had mine done to my 2008 auris other day. Part £11.50 eBay, auto electrician £20. Cheap upgrade all works to my 1.6 petrol 😀
I have a 2008 voxy engine code 3zr fae 2.0lt auto, so far ive found i have the light in dash, the spaces in the steering wheel, the right clock spring, i have plugged in the stalk and got no illumination. so investigated a little more and i have no wire in the plug position 1 (there is one in tbe ground position) behind the clock spring so i figure i need to run one to the ecu  buuut i can seem to find out which plug and pin location? Any help is grately appreciated
On 9/11/2008 at 7:51 PM, Byway said:
Hi, I have a Auris 1.4 D4D Manual transmition, and i bought the bits and install, the cruise control doesn´t worked. :angry:
I' ve found this document http://www.thecruisecontrolstore.com/toyotawiring.pdf
it says that a wire between ECU and a conector behind steering wheel is missing, the problem is that this document is for corolla and prius, and the ecu pinout is not the same.
Can anybody check this for me, anyones knows were to find the ecu pinout?
thkx!!!
Did you find a way to make it work after all?
Hi everyone, I have the exact issue this guy has:
and another guy in page 28, but never seen any solution for a long time.
Please help guys!
On 8/16/2015 at 12:24 PM, Auris 1.6 vvt-i said:
If the airbag wire is pluged in and the airbag is just dismounted from the steering wheel, it wouldn't store an error but it is extremely dangerous as if the airbag goes off, you can't even predict which way it will go and what damage it could cause... it's a ticking bomb.
Ajk126, I used to drive a 2008 Auris 1.6 VVT-i with 1ZR-FE engine and have successfully installed the CC, so if you have the same engine and it seems this way as there is only one 1.6 petrol engine for the 2008 Auris, there is nothing to worry about - it will work.
Cheers.
P.S. As a matter of fact, if I were you, I wouldn't (and I didn't) drill the cover. Trust me, no matter how handy you are, it'll be ugly! I sugest you Google these two part numbers, find them and buy them...you can thank me later :clap: 45184-02150-B0 and 45186-12010-B0. I bought them from my local Toyota dealer when installing the CC.
Good evening,
I am planning to install soon the CC on my 2008 Auris 1.6 VVT-i.
Following the suggestion from the post above, I ask for a quote for the two steering wheel parts to my local Toyota dealer:
45184-02150-B0 - £36.33 plus vat - steering wheel cover
45186-02120       - £3.42 plus vat - CC cap cover
I will buy the cap cover for sure being just £4, but I'd like to know if I can fit the cap cover by cuttting a hole (after completely removing the steering wheel) into the existing steering wheel cover. Has anyone tried this?
