Typhoon
Demo_202
Ok my final question on the matter, honest!
How did we all do it?
I was thinking of using
http://i20.ebayimg.com/02/i/07/19/08/24_1_b.JPG
or
http://www.grendle.co.uk/pics/terminalblocks.gif
Sorry about the pics, best I could find.
Im no electrician so opinion is welcome.
Thanks!
Ps. A big thanks to Norfolk who I pm'd early while I was fitting the typhoon. Very helpful chap so cheers
:thumbsup:
Still think you should've got the A'PEXi tho! :lol:
:thumbsup:
Gaz your Apexi obsession is boarding on Flexy's Camry one :lol::lol: ;)
:thumbsup:
Have you actually really gained any power from the Apexi? Or are you just imagining that you have coz it roars lol
Cheers H :thumbsup:
:o Hadn't realised i was getting as bad as Flexy! :(
Although at least my obsession is with something decent! :lol:
Cheers H :thumbsup:
Dunno, it certainly feels quicker.
If the Rolling Road day ever happens i'm tempted to put the standard airbox back on so i can have a proper comparison
:thumbsup:
I agree with Flexy, i mean Gaz :P
More low down torque and power on lift defiantly :thumbsup:
:thumbsup:
I definitely think that you and someone with a typhoon should turn up with the stock box fittted and have them rr and then switch to the Typhoon/A'PEXi and rr them again. That might finally settle the debate between the 2 as you will be rr on the same machine on the same day and both copmparing oe with aftermarket.
I guess technically, Gaz should rr his 3 times (OE, A'PEXi and then steal a Typhoon too) as that would give a truly flat benchmark.
Well Awsome GTI give 3 runs on the day so that would be possible if someone could lend me a Typhoon! :lol:
If it does go ahead then there will be T-Sports with all 3 Setups, that should give a fair set of results.
Anybody wanna find out the BHP before lift then? I know its been done with the Type R boys
I would guess about 120-130 at 6k RPM, would the rolling road show this? I guess it would.
While were on this, did someone say you could buy a wire extension from Mr T?
Cheers
Read my earlier reply, the old thread has part numbers in it, if you don’t wish to do what i did, just cut the little black wire off the plug then add a bit more wire in and reattach.
Cheers
Read my earlier reply, the old thread has part numbers in it, if you don't wish to do what i did, just cut the little black wire off the plug then add a bit more wire in and reattach.
I did read it sorry but was thinking that was something different. What were the parts you got? Just extra wire?
Cheers
Cheers
Cheers
New Plug, Internals (terminals etc) & Wires. The job looks great, i will post a picture later, note: I had to purchase a new Plug as mine was dodgy internally from when the wire snapped. So you probably only need the wires themselves, I had all the wires extended so this problem will defiantly not return :thumbsup:
Pic would be excellent cheers. Ive taken mine back off so i dont destroy the wires.
Ps. For anybody fitting one, i dont know about everyone else but the online manual was far superior to the one in the box
Can second that! K&N's online manuals are spot on, used one to install mine! :thumbsup:
The A'PEXi ones were in Japanese! :lol:
Pics below are before and after the repair:
As you can see the plug has changed along with the wires
So the plug came with new wires and you had then soldered to your existing?
Since mine isnt broken I guess the best bet is just to get an electrician to extend the cables a tad
Cheers for the help
