Badge Removal
markleo
How do you remove the badges from a car without leaving a mark? What chemical do you use to take off the sticker leftovers without damaging the paint? Thanks.
i used an old top up card to take em off and some WD40 - that loosens it up an removes the sticky stuff, when its all gone polish it and it will be gone!
To get the Badge off in the first place, use dental floss, cut a long piece, place behind Badge and use a see-saw action to cut through the tape, this prevents any possibility of damage to your paintwork, then as stated above wd40 or even petrol (if you can afford it!!!) works to get the goo off, just spray some on and leave it for 5 mins and it will come off....
