Where Is Car Audio Fuse
fads
Hello. I can't find the car audio fuse in the previa 2004 model. Says in the manual that it's in the passenger kick box. Looked there but could not find fuse. Please help.
Found the fuse but it keeps blowing as soon as it is replaced. Any advice welcome.
Is that the radio fuse which is accessory powered, so it blows when you turn the key on, or the memory backup fuse, which would blow even with the key turned off?
If it's the memory fuse, check the interior lights, one of the bulbs (which are probably festoon) might have not been installed properly when changed and shorting to ground.
If it's the accessory fuse, try unplugging the radio and see if it still blows the fuse.
