Wiring.
osoleamio
Hi, I need to run a cable from inside the engine bay, through the bulkhead and then to feed a switch under the ash tray....has anyone tried to feed a cable through please and if so, exactly where did you manage to feed it through......many thanks...m. :D
depends on what you want to feed.
I went the other way and ran cables thru bulkhead - and had some of the dash off - an easy job if you take it logically.
Whit (what) are ye daein (doing)?
You don't say which model you have.
This shows how to feed it through on a 4.2;
