Interior (courtesy)light
Diarmuid
Hi there
Have 07 Corolla Saloon. Courtesy light works as follows:
OFF: Light is off
ON: Light is on
DOOR: Light is on
and wont go off...even with ignition started.
Or
with doors closed and car locked.
Any ideas before I take it to garage.
Diarmuid
i had this problem a few weeks ago after running some wires thru the car. i had a play with the door sensor and that didnt seem to solve it. knew a mate who work as a toyota tech to take a look at it and it worked for him. sorry not much help but just have a look at the wiring on the door sensor
Ok will try and let you know ...in case it helps anyone else looking.
Diarmuid
