Heater
goyathlay
Hallo everybody,
I am new member of toyota owners club.
I have got a problem.
My Avensis 2001 blows only cold air from the heater system.
A/C is working normaly,but heater no.
This problem starts few weeks before,when heater was blowing maximum hot air after I turned heater control for only one level above the minimum.
Can somebody help?
Thanks.
Could be heater control valve sticking, therefore not allowing hot water to enter your heater matrix. Or have you checked your engine coolant level lately? Cannot have warm air without water in system, check for water leaks. But you probably would have had overheating problem by now?
HI I am having problems with my heater also but I have yet to find how you add to forum.
The problems that I am having are I turn on the blower it works but no air is comming out anywhere I try to change where the air is supposed to come out of but nothing happens any sugestioms
