Fly Wheel & Strut Brace
lift addict
can anyone tell me if the flywheel upgrade is worth the money..as in better responce etc and what atvantages does strut brace have.
All for my T Sport 03
Cant say for the flywheel, as for the strutbrace it makes a big difference, the front end is solid with much less chassis flex, combined with lowering springs its 100% better than standard. The only downside is the rear end's chassi flex is exposed due to the front being so solid, when i get my rear brace fitted hopefully i will see a marked difference :thumbsup:
What rear brace you got?
Been looking into them but don't want the TRD one as i'd have to cut the rear trim.
just get a TRD rear anti roll bar...stabilizer...not cutting, cheaper...etc
Its the TRD one, i dont mind cutting the trim as i will be keeping the car :thumbsup:
To be fair the cuts are pretty small, its only if the brace was removed it would look a bit cack, and that would be an issue only if you were looking for them :ph34r::lol:
come on Dale - you still aint fitted that yet!!!!
waiting for your thoughts to help me decide................
as for the flywheel - it has advantages and disadvantages, been looking into these a lot, quite a few available for ours. from the reviews i've read from 2zz owners its a good thing - easier to hit lift in every gear as the engine doesnt slow as quick, easier on downshifts to match the revs but more difficult to get going - apparently much easier to stall but that dont take much getting used to. defo get one when i change the clutch. got £600 to spend and cant decide what to get first?
I've got a new fidanza flywheel in my suitcase right now and when I get back I'll be buying everything to replace the clutch too. So probably in 2 weeks or so I can tell you how much of a difference a new flywheel makes :)
