Lift Bolts & Tyre Pressures
Panners
Morning,
Am gonna change my lift bolts tomorrow after having had them for a year.
Can anyone say what the list of tools are so that I don't find myself needing one once the job's started?
Also, I run 205s and the fronts always look under inflated at 36-36 psi, anyone have an idea what they should be?
Cheers.
hi i am too running 205's and myn also look under inflated although they have the correct pressure in them, strange.
cant help ya on lift bolts but do a search as they is a step by step guide on how to change them posted a while back
Thanks for info regarding how your tyres look - as ever it must be a characteristic!!
Bolts were an easy enough job to do, no fancy gear required.
Cheers.
Cheers.
Any difference after the bolt change?
